Increase Voltage Circuit (Atmel STK500)
Discussion in 'General Electronics Chat' started by frogacult, May 11, 2008.
  1. frogacult
    Apr 30, 2008
    27
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    The input voltage range of the STK500 board is 9 to 15V.
    hgmjr
  3. frogacult
    Apr 30, 2008
    27
    I;m not asking about this
    I want to make a circuit wich will generates a relay from the voltage of an outpout pin.
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    For clarification... are you attempting to convert the 4.5V to 12V, or are you wanting to use the 4.5V to control a transistor switch in a 12V circuit? The former won't be possible, the latter simply needs the correct transistor and correct connections.
    Can you post a schematic of what you've tried? And which transistor did you use?
  5. frogacult
    Apr 30, 2008
    27
    That's cool, i used wrong transistors and that's the reason i had this problem.
  6. frogacult
    Apr 30, 2008
    27
    Finally i tried both circuits and didn't worked . Should i try somthing else?
    That i am talking about, is how i can set a relay from the voltage of STK500 pin (4.5 V)
  7. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    What relay are you using? Will it operate from 4.5V? Will it draw more current than your STK500 can provide?
