Its also worth remembering that manufacturers quote the Ah capacity over something like 10 or 20 hour discharge rate.simple answer is NO. Now you need to define how you came to the 20 AHr figure. Factory ratings are mostly "total depletion" points, or 11 volts or less under load for 12 volt battery. Discharges around 50%, which are considered normal and not deep discharge, make your 20 Ahr figure close to expected value
You should use a charge balancing circuit to insure that you do not under-charge one or more batteries in a series-parallel configuration.@GopherT I would like to make a small correction about your post. Please take a look at the next link: http://blog.thesolarbiz.com/page/10/ It looks like not a good idea to connect batterys parallel. Or am i wrong? Btw, sorry for my poor English.
by Jake Hertz
by Duane Benson
by Jake Hertz
