Increase range of BA1404 transmitter by using RF receiver amp
Discussion in 'Wireless & RF Design' started by senakahks, Oct 24, 2015.
  1. senakahks
    Apr 6, 2009
  2. DickCappels
    Aug 21, 2008
    2,792
    678
    Maybe if you can adjust the output circuit (L2 and its three capacitors) to get a 50 ohm output. Note that increasing the output might cause problems with broadcasters, neighbors, and the government.
  3. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
    The given link has an amplifier for the receiver end.
    It has not the power for a transmitter application.
    Bertus
  4. senakahks
    Apr 6, 2009
    I purchased that RF amplifier after looking at following schematic.
    Can somebody guess the 4 pin IC here? following link recommends above circuit for BA1404 transmitters.
    http://electronics-diy.com/BA1404_Stereo_FM_Transmitter.php
    Also will this kind of additions change the output frequency or generate harmonics? If so dangerous to use.
  5. bertus
    Administrator
    Apr 5, 2008
    15,809
    2,390
  6. BR-549
    Sep 22, 2013
    2,185
    421
    Usually, raising the antenna and shortening the feed line works much better.
