Another wonderful Rube Goldberg solution!Use a phase -locked loop. Square up the 50 Hz to a square wave. The PLL [LM565], has a voltage controlled oscillator which will multiply, with proper components,the 50Hz to 400 Hz, use divider to divide by 5 giving 80 Hz. Dividing by 8 gives Almost 50 HZ which is comared to origional 50Hz & generating a correction V to VCO to make divided down 50 Hz exactly same as origional, the 400 HZ then is then also exact, giving an exact 80 HZ square wave. Use class D amp to give desired operating voltage & filter. LED current limiting resistors can be part of filter. Use a high V out [48V], to shorten the number of LED strings. At least I think that is how it works.
I'm not making fun of you and studiot, I'm making fun of the OP's supervisor.
If he was doing PWM, this frequency conversion would make sense, but he said it was a sine wave.
If it turns out there is a good reason for doing this, I'll have to develop an appetite for crow.
