Increase current for 10V output having 5V power source
Discussion in 'General Electronics Chat' started by palkapalka, Aug 15, 2015.
  1. palkapalka
    Aug 15, 2015
    11
    I have output of 10V with low current. I also have power source of 5V with 500mA current (USB).
    How can I combine these things to get 10V with high current?
    I thought about buffer opamp - but output will be limeted to rails voltage (5V).
    I do not want to use additional step-up converters.
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    Can't be done. Even if you use a step-up converter, you'll get less than a couple hundred mA at 10V. Additionally, you can't draw more than 100mA from a USB port unless you negotiate with the host and are allowed a higher current.
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    The best you can do is about 200mA @ 10V, and that is only by using a step up converter.
    I never cease to be amazed at why folks want to steal power from a USB port when these things are almost free at thrift shops and garage sales.
    #12 likes this.
  4. #12
    Nov 30, 2010
    16,685
    7,327
    I think we're having a problem with the definition of, "step-up converter". What else could increase the voltage of a 5VDC source? Until DC transformers are invented, you are stuck with making some sort of a converter.
  5. palkapalka
    Aug 15, 2015
    11
    Thank for the prompt response.
    200 mA limit I understand.
    Can I boost 10V signal to say 50mA?
    The only reason I do not want step-up converters is to avoid additional coils in my schematic.
  6. mcgyvr
    Oct 15, 2009
    4,791
    975
    We don't know..
    Where is the 10V "signal" coming from?
    Whats its source?
  7. palkapalka
    Aug 15, 2015
    11
    I use voltage doubler to get 10V from 5V usb - but it drops current. And I want my usb current back - at least portion of it.
  8. #12
    Nov 30, 2010
    16,685
    7,327
    This might work.
  9. palkapalka
    Aug 15, 2015
    11
    Thank #12.
    I will consider this ic
  10. dl324
    Mar 30, 2015
    3,377
    651
    It still requires an inductor.
  11. #12
    Nov 30, 2010
    16,685
    7,327
    If you don't like inductors, you are welcome to name a switched capacitor converter for this job...or any other method.
    Perhaps a 555 used as an oscillator with a voltage doubler rectifier configuration?
  12. palkapalka
    Aug 15, 2015
    11
    Is this what you mean: http://www.instructables.com/id/555-Voltage-Doubler/
    It says - "This circuit is only practical for low current devises".
    But "low" current is different for different applications.
    What current can I get from this circuit?
  13. #12
    Nov 30, 2010
    16,685
    7,327
    The comments on that page show this:
    "my multimeter showed 18v@ 0.20A on the 10A setting, while using the circuit to power my 80mm 3-wire pc case fan at the Vin pin of the 555ic chip. i had 14v @ 0.14A from Vout to the pc fan."
    palkapalka likes this.
