I am trying to get a K53 Kinetis Freescale microcontroller and an ADAS1000SDZ Analog Front End microcontroller to talk to each other. I have the setup for sending words done and I can see the TX FIFO correctly being updated with the words I must send to the AFE (slave) to set control registers in the AFE and to send commands to the AFE to send back data.
I am able to get some data received only in debug mode. When I run the program normally, I just get zeros.
Moreover, the data that I am receiving in debug mode is not correct. I know this because If I must read the data at an address 0x11, I should get a 32 bit word whos MS bytes should be 0x11. i.e, 0x11abcdefg. This is not happening, or is happening too sporadically to say that I've succeeded.
One issue I had initially was timining. I've configured the ADE to output data at 2kHz and I should be having a minimum SCLK (master clock) of 768kHz. I had it too high, initially, and was receiving no data at all. Having lowered the SCLK to about 1500 kHz, I am receiving this incorrect data.
I have attached my code for writing to registers and the initializations. Any suggestions would be much appreciated as I have spent quite a bit of time trying to get the correct data in, trying out different combinations of clock polarity and so.
My Initializations are like so:
And the way I write to registers is byte by byte, so for 32 bit word I must push 4 times for one word.
Moderators note : Please use code tags for pieces of code
Code:
SPI0_MCR = ((SPI_MCR_HALT_MASK) | //halts transfers
(SPI_MCR_MDIS_MASK & 0x00)); //enables module clocks
SPI0_MCR = (SPI_MCR_MSTR_MASK )| //master mode
(SPI_MCR_ROOE_MASK)| // incoming data shifted into shift register
//overwriting previous data
//when RX FIFO is full
(SPI_MCR_DCONF(0x00))| // SPI
(SPI_MCR_PCSIS(1))| // determines inactive state of PC(X):
// 0 : inactive PC(x) is low
(SPI_MCR_DIS_TXF_MASK)|
(SPI_MCR_DIS_RXF_MASK)|
(SPI_MCR_CONT_SCKE_MASK && 0x00); //continuous SKE enable
SPI0_CTAR0 = (SPI_CTAR_DBR_MASK & 0x00) |
(SPI_CTAR_FMSZ(0x07)) | //frame size = 8bits
(SPI_CTAR_PDT(0x00)) |
(SPI_CTAR_BR(0x04)) | //was 0x07 //baud rate prescaler
(SPI_CTAR_CPOL_MASK & 0x00) |
(SPI_CTAR_CPHA_MASK & 0x00) |
(SPI_CTAR_PBR(0x02)) | //was 0x02 /pre baud prescaler
(SPI_CTAR_PCSSCK(0x02) |
(SPI_CTAR_PASC(0x00)) |
(SPI_CTAR_CSSCK(0x06)) |
(SPI_CTAR_ASC(0)) |
(SPI_CTAR_DT(0))) ; // mode 0 operation
SPI0_MCR &= 0xfffffffe ; //start transfers again
Code:
int register_configure(int address)
//int data[5];
int data;
unsigned int data1,data2,data3,data4;
int address1, address2, address3,address4;
address1 = address & 0x000000ff;
address2=address & 0x0000ff00;
address2 = address2>>8;
address3 = address & 0x00ff0000;
address3 = address3>>16;
address4 = address & 0xff000000;
address4 = address4>>24;
address4 = address4 & 0x000000ff;
SPI0_PUSHR = ((SPI_PUSHR_CTAS(0x00)) | //The CTAR0 is selected
(SPI_PUSHR_CONT_MASK) | //Chip select is continuous through transfers
SPI_PUSHR_TXDATA(address4))|
SPI_PUSHR_PCS(1) ; //Pushes the required data
while((SPI0_SR & SPI_SR_TCF_MASK)==0){}//wait till the transfer is complete
data1 = SPI0_POPR; // the latest data in the RX FIFO is transferred to data1
while((SPI0_SR & SPI_SR_TFFF_MASK)==0); //wait till the TX FIFO is not empty
while((SPI0_SR & SPI_SR_RFDF_MASK)==0); //wait till the RX FIFO is not empty
SPI0_SR |= SPI_SR_TFFF_MASK; // TX FIFO is not empty set
SPI0_SR |= SPI_SR_RFDF_MASK; //sets the RX FIFO is not empty flag
SPI0_SR |= SPI_SR_TCF_MASK; //Transfer is complete flag set
SPI0_PUSHR = (SPI_PUSHR_CTAS(0x00)) |
SPI_PUSHR_TXDATA(address3)|
SPI_PUSHR_PCS(1); //CS is asserted
data2 = SPI0_POPR; // the latest data in the RX FIFO is transferred to data1
SPI0_SR |= SPI_SR_RFOF_MASK;
SPI_PUSHR_TXDATA(address2)|
SPI_PUSHR_PCS(1);
data3 = SPI0_POPR; // the latest data in the RX FIFO is transferred to data1
SPI_PUSHR_TXDATA(address1)|
SPI_PUSHR_PCS(1));
data4 = SPI0_POPR; // the latest data in the RX FIFO is transferred to data1
data = (((data1<<24) & 0xff000000)|((data2<<16)&0x00ff0000)|((data3<<8)&0x0000ff00)|(data4 & 0x000000ff));
return data;
