The goal is to create glowing bulbs on sticks, literally 1000 of them, and plant them into the ground to light a path. I was thinking bright LED lights inside ping pong balls with holes drilled in them. I can get 1000 premade LED lights ordered from china for $250 cdn. I plan on taking them apart and using these components to build my idea.
Problem 1: Duration
I need these lights to light this pathway for no less than 3 nights. These lights if left on last about 30h, losing brightness after about 15. The battery is not built for extended use like I'm planning. So I need to have a way to switch them off automatically during the day.
My first thought was to simply have a light sensor switch the LED on when the sun went down. This may be enough to make it work. I'm wondering if someone could sketch me a basic diagram of how to sire that.
Then I started getting fancy and here's where I need the most input... Getting fancy and way over my head, I thought about using RF to switch the lights on and off. I wanted to know how this is done (again, schematic would be useful). I might want a base station where I could switch either with just light sensing, or possibly something fancy like motion, sound, and/or light.
Problem 1: Duration
