in Quartus how can i calculate 2(4bit) number addition process
Discussion in 'Embedded Systems and Microcontrollers' started by ValarVictorius, Dec 6, 2015.
  1. ValarVictorius
    Nov 17, 2015
    19
    How can i addition 2 (4 bit) number in altera quartus program with only one mux(multiplexor) and write the result to led's or 7segment screen ?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Schematic or VHDL. Which do you prefer?
    ValarVictorius likes this.
  3. ValarVictorius
    Nov 17, 2015
    19
    i prefer VHDL, but i don't say no to both solution ;)
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    What are the inputs and outputs of the multiplexer?
  5. ValarVictorius
    Nov 17, 2015
    19
    It doesn't matter for me. Make what are you want it ;)
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    In Quartus you have two methods of design input. HDL (Hardware Description Language) or schematic entry. When you use schematic entry you usually have access to a library of modules. One of the modules in a library is likely to be a multiplexer of some description. I need to know what kind of multiplexers you have available. What's so hard about that?
  7. ValarVictorius
    Nov 17, 2015
    19
    I watched tutorial videos, write some hdl codes. But i don't run my code anywhere.
    Debasedly Ex:
    module part1(SW,LEDR);
    input[9:0] SW;
    output [9:0] LEDR;
    assign LEDR=SW;
    endmodule
    How can i see how my code working ?
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It looks like you are trying to write VHDL. To see your code working you need a functional simulator, or you need to do the syntheses step and load the code into an actual device.
