I have an ice maker that has a problem.
The circuit board is mega $s.
The problem is: The water solenoid is energized for an excessively long time.
What I need is to open the circuit to the water solenoid for say 15 seconds after the circulating pump is energized. (115 VAC)
I would like to install a plug in relay to eleminate this problem.
I just do not know where to get a relay that has Normally Closed contacts that has timed to open after energizing the coil.
Any help is most appreciated.
