in need of a 16bit display solution
Discussion in 'General Electronics Chat' started by CaliusOptimus, Mar 16, 2007.
  1. CaliusOptimus
    Aug 14, 2005
    59
    im looking for some way to convert a 16bit output into a display with 5 individual 7seg displays. its for a project i have going with my OOPic micro controller. a discrete ic would be nice, even though it would mean a 50+ pin chip, it doesnt matter in this case. i cant use a software solution due to the lack of IO lines and processing speed. ANY hardware solution would be greatly appreciated! thanks!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Use external BCD counters. Send a counting clock to them from the PIC, while decrementing the 16 bit value down to zero. You'll need two pins, one for a clear signal, and the other for the count.
