Hello...
Was wondering if I could get a little direction...I'm trying to read the voltage on two ADC pins of a PIC18F4550, but not concurrently. The readings are taken on demand within a switch statement, and if the ADCON0 register (which chooses the channel) is set in a function outside the switch statement, I have no problems in taking readings by setting the ADCON0.GoDone bit within the switch statement.
I'm just trying to find a way to set-up the adc register, and then select which adc channel to sample within the switch statement...the code below is just a small excerpt
thanks for looking
Rich (BB code):
void main(void)
InitialiseSystem();
adc_init();
while(1)
USBDeviceTasks();
ProcessIO();
void adc_init(void)
ADCON1 = 0b00001101;//VSS,VDD ref. AN0 and AN1 analog only
ADCON0 = 0x00;//clear ADCON0 to select channel 0 (AN0)
ADCON2 = 0b00001000;//ADCON2 setup: Left justified, Tacq=2Tad, Tad=2*Tosc (or Fosc/2)
ADCON0bits.ADON = 0x01;//Enable A/D module
void selectchannelan1(void)
ADCON0 = 0x00;
void selectchannelan2(void)
ADCON0 = 0x04;
void ProcessIO(void)
if((USBDeviceState < CONFIGURED_STATE)||(USBSuspendControl==1)) return;
if(!HIDRxHandleBusy(USBOutHandle))
switch(ReceivedDataBuffer[0])
case 0x04:
selectchannelan1();
DelayUs(10);
ADCON0bits.GO_DONE = 1;//Start A/D Conversion
while(ADCON0bits.GO_DONE != 0);
ADC_VALUE_ARID = ADRESH;
ToSendDataBuffer[0] = 0x04;
ToSendDataBuffer[1] = ADC_VALUE_ARID;
if(!HIDTxHandleBusy(USBInHandle))
USBInHandle = HIDTxPacket(HID_EP,(BYTE*)&ToSendDataBuffer[0],64);
DelayMs(5);
break;
