impulse response
Discussion in 'Homework Help' started by hamza324, Sep 21, 2011.
  1. hamza324
    Jul 10, 2011
    33
    i want to know the impulse response to the following
    4y''(t) = 2x(t) - x'(t)
    I am able to solve this problem without the x'(t) on the right hand side but i am not sure how to deal with x'(t). The way i was told to this is to integrate it through "0 negative " to " 0 positive" thanks
  2. tgotwalt1158
    Member
    Feb 28, 2011
    111
    18
    I find a clue from my old differential equation recollection, might help you!
      File size:
      5.1 KB
      28
    hamza324 likes this.
  3. hamza324
    Jul 10, 2011
    33
    thanks.this will help..
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    Another approach might be using the Laplace Transform
    or
    For which the impulse response is the inverse transform of H(s), giving the output y(t) as ....[for t>=0]
    y(t)=\frac{t}{2}-\frac{1}{4}
    Which agrees with tgotwalt1158's solution.
  5. hamza324
    Jul 10, 2011
    33
    thanks for your help...this is helpful...
  6. hamza324
    Jul 10, 2011
    33
    i solved another question for impulse response
    y'' + 9 y= -6x'
    after doing laplace i get
    Y = -6s/(s^2 + 9)
    and so y(t) =-6 cos3t .
    is it correct..??
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    That's correct
