Impossible problem or not?
Discussion in 'Homework Help' started by Hogar, Jan 17, 2013.
  1. Hogar
    Jan 17, 2013
    8
    Help :confused:
  2. DumboFixer
    Feb 10, 2009
    219
    34
    You'll need to show your working first, to show that you have at least attempted it. That way you can be given guidance.
  3. Hogar
    Jan 17, 2013
    8
    I have no idea at all how to start. Actually I did not even certain if this problem is solvable. And this is not actually my homework. :( Sorry
  4. crutschow
    Mar 14, 2008
    13,482
    3,368
    Is that all the information you have about the problem?
  5. WBahn
    Mar 31, 2012
    18,085
    4,917
    Consider this. I have a 12V battery with two parallel resistors connected to it. One resistor is dissipating 12W, what is the size of the other resistor?
    absf likes this.
  6. Hogar
    Jan 17, 2013
    8
    Yes, this is all info.
  7. Hogar
    Jan 17, 2013
    8
    To be completely honest I do not possess virtually any knowledge of electronics. :(
    I am very interested to see the final solution of this problem with or without the solution procedure.
    Thank you.
  8. WBahn
    Mar 31, 2012
    18,085
    4,917
    Okay, how about this one: My car gets 30mpg and I live 60 miles from where I work. How big is my gas tank?
    If you have no knowledge of electronics, then what is the point of even looking at a problem like this? Whether it has a solution or not, you would lack the knowledge to know how to find it or to understand what the solution might mean once it was found.
    What is the point of this problem -- meaning, what is the context of why you are trying to work it? That might help us figure out what the best way is to help you toward that goal.
  9. Hogar
    Jan 17, 2013
    8
    It is some kind of bet. And as I do not have the necessary knowledge of electronics I'd like to hear what the experts think about this. Of course I would love to see finally solution to the problem if it exists. And if this problem is not solvable I like to hear that too, without analogy if posible. ;)
    PS
    Oh now I remember, the problem supposedly has many possible solutions. Any solutions is valid.
  10. WBahn
    Mar 31, 2012
    18,085
    4,917
    If we assume that the components are ideal -- and we pretty much have to make the assumption -- then you can pick the inductor and capacitor values at random and be all but guaranteed that you have a "solution". I'm not sure that you could even find a set of values that would not be a "solution".
  11. praondevou
    Jul 9, 2011
    2,936
    489
    If a simulation that works with ideal components is good enough to win your bet here it comes:
    Pretty useless... :p
      File size:
      29.5 KB
      42
    Hogar likes this.
  12. Hogar
    Jan 17, 2013
    8
    Thanks a lot for the effort.
    But can it do the same thing without the resistors R2 and R3? :confused:
  13. praondevou
    Jul 9, 2011
    2,936
    489
    Not with Multisim (the simulation I used).
    Anyway, every coil has a resistance, every wire has too.Every capacitor has a resistance and inductance part too. Every wire has inductance (although negligible in this case.
    The true resistance for such a big inductor is much more than 0.1R.
    Hogar likes this.
  14. Hogar
    Jan 17, 2013
    8
    I played with the online Sim tools and looks that changing the value of L1 elements can fine-tune the voltage at the resistor R1. Is there an equation that describes how the value of L1 elements affect the value of the voltage at the resistor R1?:confused:
  15. WBahn
    Mar 31, 2012
    18,085
    4,917
    I still don't see the goal. Okay, it's a bet of some kind. Fine. But what constitutes a solution? You have two ideal voltage sources, which mean that they will drive the nodes they are connected to at their terminal voltages no matter how much current they have to supply in order to do it. Be it 0A, 10A, a trillion amps, or infinity. You have a lamp with a fixed DC voltage across it that is dissipating 100W, so it has whatever resistance is needed to dissipate 100W with that voltage across it. The right hand capacitor is clamped to the DC voltage of the right hand source, so it has some charge that is fixed and unchanging. So the only thing that could cause a problem would be for the rest of the components to result in a short, at the frequency of the AC source, between the terminals of the two sources.
  16. WBahn
    Mar 31, 2012
    18,085
    4,917
    Fine tune it TO WHAT??? "Fine tuning" something implies that it isn't quite what you want and so you tweak something to get it closer to what you want. What do you want the voltage at resistor R1 to BE?
  17. Hogar
    Jan 17, 2013
    8
    This is how I understood the problem.
    I have one AC source at the left. With three capacitors and two coils I must raise the initial AC voltage to 230 volts that 100 watt incandescent light bulb will light at full power. At the right side is voltmeter with reading not a DC source.:)
  18. Ron H
    Apr 14, 2005
    7,050
    657
    That's my interpretation also.
    And C1 is redundant. Was that mentioned already?
