Importing models into LTSpice
Discussion in 'General Electronics Chat' started by udaykiran balusu, Jun 24, 2015.
  1. udaykiran balusu
    Jun 23, 2015
    hi i am working on LT spice for phase shifted dc-dc converter.I need to calculate efficiency of the circuit which i cannot do because its not internal model.can u tell me the way to calculate the efficiency of the circuit.i uploaded my circuit file.please check it out.
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    Welcome to AAC!
    A thread belongs to the OP (original poster). Trying to take over someone elses thread is called hijacking, which is not allowed at All About Circuits. I have therefore given you a thread of your very own.
    This was split from Importing models into LTSpice
  3. Bordodynov
    May 20, 2015
    673
    194
    I can help you,if you finish work.
    You have all your files packaged in zip archive(models, symbols and the electronic circuit).I have an extensive library of models and symbol,but your not. The idea is that on your electronic circuit an element is placed by LT.This element never joins except GND.
  4. Alec_t
    Sep 17, 2013
    5,979
    1,138
    Your .asc file is not useful without either all the necessary models or some text annotation to indicate which active components are used.
