I CONNECTED +VE OF DC SOURCE(15V) TO A RESISTOR(100KΩ),WHEN I MEASURED POTENTIAL ACROSS -VE OF SOURCE AND ANOTHER END OF RESISTOR I COULD MEASURE ABOUT 13V,EVEN WHEN I MADE MY BODY AS RESISTOR I COULD GET 12V.
HOW CAN THIS HAPPEN?
WHEN WE CONSIDER -VE TERMINAL AT GROUND POTENTIAL,THEN +VE TERMINAL IS +15V(IT ACCEPTS ELECTRON AT A POTENTIAL 15V).
BUT WHEN THIS +VE TERMINAL IS CONNECTED TO HIGH RESISTANCE ,THE POTENTIAL BETWEEN RESISTOR ANOTHER END AND -VE OF SOURCE SHOULD REDUCE A LOT .BECAUSE IT ALLOWS ONLY FEW ELECTRONS TO PASS THROUGH.THUS THE DIFFERENCE IN ELECTRON LEVEL DECREASES THUS POTENTIAL SHOULD REDUCE.
WHY IT DONT HAPPEN?
WHY IT DONT HAPPEN?
