Implementing demodulation in a different way
Discussion in 'Wireless & RF Design' started by atferrari, Feb 7, 2012.
  1. atferrari
    Thread Starter AAC Fanatic!
    Jan 6, 2004
    2,663
    783
    I revisited the concept of demodulation of an AM signal.
    Isn't the output of the 455 KHz IF filter, similar to a sampled signal as I could get from a DAC process?
    If so (in the hope of not being wrong assuming the above) could I obtain the baseband just by using an active filter implemented with opamps of suitable GBW, surely very expensive/hard to find?
    What are the flaws of my reasoning?
  2. crutschow
    Mar 14, 2008
    13,469
    3,356
    There is no baseband signal in the 455kHz IF signal. It consists of the 455kHz carrier with sidebands at plus and minus the modulation frequencies around the carrier.
  3. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    Have a look at this page how a AM signal looks like:
    http://www.williamson-labs.com/480_am.htm
    An other way of demodulation an AM signal is a synchronized demodulator.
    Most times a PLL is used for the synchronized signal needed for the demodulation.
    Bertus
  4. atferrari
    Jan 6, 2004
    2,663
    783
    What about telling if I can recover the audio with what I propose?
  5. crutschow
    Mar 14, 2008
    13,469
    3,356
    Sorry you didn't understand my answer. It was "NO". :rolleyes:
