Implementing a boolean function using a single 8:3 decoder and a single nand gate
Discussion in 'Homework Help' started by dogadikbayir, Oct 20, 2013.
  1. dogadikbayir
    Oct 18, 2013
    12
    ok so I am asked to implement the following boolean function: F(w,x,y) with these minterms (0,2,3,5). I am allowed to use a single decoder(74138) and a single nand gate. I found the solution using De Morgan's laws of logic but it seems like I need inverters for the minterms 0,2,3,5. Please help me...
    thank you...
  2. WBahn
    Mar 31, 2012
    18,087
    4,917
    As usual, you need to show YOUR attempt to solve YOUR homework problem. Then we can look at what you've done and where you need to go and make suggestions that will hopefully steer you down that path.
    dogadikbayir likes this.
  3. dogadikbayir
    Oct 18, 2013
    12
    ok my solution is like this: I have one 3x8 decoder with bubbles on each output and 0,2,3,5 connected together to a single NAND gate. This is right I've tested it however the task is like this: "Implement F with a single decoder and a single NAND gate".
  4. ScottWang
    Aug 23, 2012
    4,933
    777
    The title ... using a single 8:3 decoder
    But you using 74138, that is 3:8 decoder, does some mistake of the title?
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    You have the right idea. When you say that you've tested it, how did you test it? In simulation or with the real IC? If in simulation, did you use the model for the 74138 specifically, or just a generic 3:8 decoder?
    Go look at the datasheet for the 74138 and I think you'll see your problem and how to fix it.
