I found but it is not correct. I used only 2x4 but I must use 1x2 and 2x4.You need to show YOUR attempt to solve YOUR homework problem. That gives us a starting point for discussion in OUR attempt to guide YOU toward finding your own path to the correct solution.
There is no information about it. Actually, I dont know too much about the one which has enable input, I tried to implement it using decoders which has no enable input.Do the 2x4 decoders you are using have output enable inputs on them?
Few hints:There is no information about it. Actually, I dont know too much about the one which has enable input, I tried to implement it using decoders which has no enable input.
by Duane Benson
by Jake Hertz
by Jake Hertz
