Implementing 12 button keypad into circuit
Discussion in 'Homework Help' started by mechgirl, Nov 8, 2010.
  1. mechgirl
    Nov 8, 2010
    For a school project my group is making an automatic car starter. We are trying to implement a 12 button keypad into our controller for the user to enter a passcode. We are working with a PIC 16F88 micro controller
    We have a LCD interfaced to the PIC through an EDE 702 chip and know that the LCD works because it displays the information we want it to.
    We are having problems with our 12 key input though.
    We are using a 12 key input that is connected to an EDE 1144 chip, of which is connected to the PIC as follows:
    From EDE 1144 to PIC 16F88
    XMIT to PortB.0
    Valid to PortB.1
    When the system starts up our "test" mode works properly, but when we click the "1" or "2" key on the 12 key input, the system doesn't change to the next stage in the code. We are using PIC Basic Pro to program the 16F88. I think it is a coding problem as our circuit is setup properly according to the data sheets. Any help would be appreciated. Thanks!
    Here is our program:
    'Identify and set internal clock speed
    Define OSC 8
    OSCCON.4=1
    OSCCON.5=1
    OSCCON.6=1
    CMCON.0 = 1
    CMCON.1 = 1
    CMCON.2 = 1
    CVRCON.6 = 0
    CVRCON.7 = 0
    'Turn off A/D converter
    ANSEL=0
    I Var byte
    key_serial Var PortB.0
    green Var PortB.2
    red Var PortB.3
    key_value Var byte
    key_mode Con 0
    key_1 Con $30
    key_2 Con $31
    key_3 Con $32
    key_4 Con $34
    key_5 Con $35
    key_6 Con $36
    key_7 Con $38
    key_8 Con $39
    key_9 Con $41
    key_star Con $43
    key_0 Con $44
    key_pound Con $45
    Pause 100
    Low green
    Pause 100
    Low red
    Pause 100
    Pause 4000
    'Set loop counter to 0
    I=0
    test:
    'Test to make sure system is working
    SEROUT PortA.0, 0,[$FE, 1, "**Testing**"]
    Pause 100
    High green
    PAUSE 1000
    Low green
    PAUSE 100
    High red
    PAUSE 1000
    Low red
    PAUSE 100
    SEROUT PortA.0, 0,[$FE, 1, "*System Ready*"]
    PAUSE 1000
    Gosub main_menu
    Gosub loop
    'Main program loop
    loop:
    Serin key_serial, key_mode, key_value
    IF(key_value = key_1) Then
    SEROUT PortA.0, 0,[$FE, 1, "Enter Passcode"]
    SEROUT PortA.0, 0,[$FE, $C0, "* or #: Main Menu"]
    Gosub code
    ELSE
    IF(key_value = key_2) Then
    Gosub test
    ENDIF : ENDIF
    Gosub loop
    END
    main_menu:
    SEROUT PortA.0, 0,[$FE, 1, "Main Menu:"]
    SEROUT PortA.0, 0,[$FE, $C0, "1:Start, 2:Test"]
    Return
    code:
    If(key_value = key_1) Then
    Gosub program
    Else
    If(key_value = key_2) Then
    Gosub wrong_passcode
    Else
    If(key_value = key_3) Then
    Else
    If(key_value = key_4) Then
    Else
    If(key_value = key_5) Then
    Else
    If(key_value = key_6) Then
    Else
    If(key_value = key_7) Then
    Else
    If(key_value = key_8) Then
    Else
    If(key_value = key_9) Then
    Else
    If(key_value = key_0) Then
    Else
    If(key_value = key_star) Then
    Gosub main_menu
    Else
    If(key_value = key_pound) Then
    Gosub main_menu
    Endif : Endif : Endif : Endif : Endif : Endif
    Gosub code
    End
    wrong_passcode:
    SEROUT PortA.0, 0,[$FE, 1, "Wrong Passcode"]
    Pause 1000
    Gosub code
    program:
    Low green 'Green led set to off
    Low red 'Red led set to off
    WHILE(PORTA.2==1)
    'If there is no system response within approximatly 10 seconds, turn on red led
    IF(I==10)THEN
    SEROUT PortA.0, 0,[$FE, 1, "System Timed Out"]
    Pause 10
    High red
    PAUSE 1000
    Else
    I=I+1
    IF(PORTA.3==0)Then
    SEROUT PortA.0, 0,[$FE, 1, "System Running"]
    Pause 10
    High green
    PAUSE 1000
    Low green
    PAUSE 100
    Endif
    While(PortA.3==1)
    SEROUT PortA.0, 0,[$FE, 1, "*System Error*"]
    Pause 10
    High red
    PAUSE 100
    Wend
    PAUSE 100
    ENDIF
    WEND
    GOTO program
    Return
    END
