Implement state machine without using MCU
Discussion in 'General Electronics Chat' started by rbgautam, Oct 29, 2015.
  1. rbgautam
    Nov 22, 2014
    I want to implement a simple lighting circuit, which moves from one state to another using a simple momentary switch. The modes are as follows:
    Bright mode -> Dim Mode -> Strobing mode -> Off
    I want to use only one switch and minimum of components.
  2. Brownout
    Jan 10, 2012
    2,375
    998
    What's stopping you?
  3. DickCappels
    Aug 21, 2008
    2,773
    669
    Google Search: debounced sequencer with CD4017
    Does this give you any ideas?
  4. Brownout
    Jan 10, 2012
    2,375
    998
    It will be hard to stop it on the desired state.
  5. atferrari
    Jan 6, 2004
    2,667
    784
    Controlling the clock?
  6. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,697
    1,297
    Here on earth there are 47,139 different kinds of lights (I checked). Which one is yours?
    ak
  7. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    That's exactly the behavior of our TechLite Lumen Master flashlight. Maybe there is a mass-produced flashlight chip that you can buy, or you can harvest the circuit from a flashlight?
    Alternatively, why not use an MCU? A simple one like a PICAXE 08M2 is capable of doing what you want, including debouncing the pushbutton. Not that hard to learn, and trivial to program (you just use BASIC). Comes in an 8-pin DIP, that's pretty simple and small. No external oscillators. About all you would need is an external pass transistor to handle the current of your LED.
  8. PeterCoxSmith
    Member
    Feb 23, 2015
    148
    38
    Use a 4 stage ring counter circulating 1000. Clock with the switch, with debounce. Enable each mode by one-hot state.
  9. WBahn
    Mar 31, 2012
    18,087
    4,917
    This seems a lot like a homework assignment. Is it?
