Implement FM TX using PLL
Discussion in 'The Projects Forum' started by ericyeoh, Jun 23, 2011.
  1. ericyeoh
    Thread Starter Active Member
    Aug 2, 2009
    58
    Hi guys,
    Is it possible to implement the FM TX using PLL concept but no to use just a simple chip?
    What i mean is that could i build the circuit for each block contained in the PLL. Such as N-divider, VCO, LPF, Phase detector.
  2. #12
    Nov 30, 2010
    16,665
    7,313
    PLL's have been in existance since 1932. Those people did not have transistors, so I expect you can do it also.
