Implement Boolean function using 4x1 MUX
Discussion in 'Homework Help' started by goofiesnacks, Oct 18, 2012.
  1. goofiesnacks
    Oct 18, 2012
    Implement F(A,B,C,D)= Ʃ(0,2,5,6) using a 4x1 MUX and inverters.
    Can someone walk me through this? I'm new to the concept of multiplexers so I'm having trouble understanding this right now. Would you first create a truth table for this function? What has to be done from there?
  2. JoeJester
    Apr 26, 2005
    3,402
    1,227
  3. WBahn
    Mar 31, 2012
    18,088
    4,917
    Just a single 4:1 MUX, as in a circuit with four data inputs and then two control inputs that determine which of the four data inputs is sent to the output? In general, you can't make an arbitrary truth table with just these components, but if the entries are chosen carefully, you can.
  4. djsfantasi
    Apr 11, 2010
    2,911
    881
    Are you limited to one 4-1 mux?
