Implement a full adder for two 2 bit binary numbers by using (4:1) multiplexer
Discussion in 'Homework Help' started by Nec, Nov 21, 2008.
  1. Nec
    Nov 21, 2008
    6
    Hi all,
    How can implement a full adder for two bit binary numbers by using (4:1) multiplexer?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Make a truth table for the various combinations of the bits. Arrange the multiplexer to select an output based on the truth table.
  3. Mithryll
    Nov 22, 2008
    6
    Can you explain a little? I dont understand how to do it?
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Look at the data sheet for a multiplexer like a 74153. See what it takes to select the input that gets connected to the output. Should be pretty obvious from there.
  5. Mithryll
    Nov 22, 2008
    6
    can you write it? if you have time?
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Write the data sheet? It's already been done - www.[B]datasheet[/B]catalog.com/datasheets_pdf/7/4/1/5/74153.shtml - 15k.
    If you are referring to the truth table for a two bit ADD, surely you can work that out?
  7. Mithryll
    Nov 22, 2008
    6
    not so detailed we saw.. question just wants the implement a full adder for two 2-bit binary numbers by using 4:1 multiplexer modules. and it says don't use additional gates.
  8. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Have you worked out the truth table?
  9. Mithryll
    Nov 22, 2008
    6
    yes i can draw a simple truth table but still i didn't understand the solution of this.
  10. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Use each pair of bits to address a multiplexer. insure the inputs are arranged such that the output agrees with the truth table.
  11. Mithryll
    Nov 22, 2008
    6
    is this a true truth table?
    A1 A0 B1 B0 | S1 S2 C1 C2
    0 | 0 | 0 | 0 | 0 | 0 | 0 | 0
    0 | 0 | 0 | 1 | 1 | 0 | 0 | 0
    0 | 0 | 1 | 0 | 0 | 1 | 0 | 0
  12. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It is a fraction of one. Make the full truth table with the carries included, and you will be able to tell how many multiplexers will be needed.
    Yes, I'm being a bit dense, but it is your assignment. You really need to do some thinking on your own instead of leaning on us.
  13. Mithryll
    Nov 22, 2008
    6
    thanks, i'm trying on it.
