implement a dither signal on a pwm signal to control a servo valve
Discussion in 'General Electronics Chat' started by navidelec, Jan 7, 2015.
  1. navidelec
    Jul 12, 2014
    29
    I would like to implement a signal on a pwm signal, what is the requirements and limitation through this?
  2. crutschow
    Mar 14, 2008
    13,519
    3,386
    The main requirement is that the PWM frequency be higher than the Nyquist limit of twice the highest modulation frequency. For good response a value at least 10 times the highest dither frequency or ≥3000Hz is recommended..
    navidelec likes this.
  3. navidelec
    Jul 12, 2014
    29
    dear friend, I should take this requirement as a report to my presentation, where can I find this requirements, I mean a text or book or ...?
  4. crutschow
    Mar 14, 2008
    13,519
    3,386
    Look up Nyquist sample rate. This applies to all sampling systems including PWM.
  5. navidelec
    Jul 12, 2014
    29
    I wonder if you tell me what should I do?
  6. crutschow
    Mar 14, 2008
    13,519
    3,386
    The servo likely has inductance which will smooth and average the PWM pulses into a steady current, which is what you want. A higher frequency actually helps, since there is less ripple in the average current value.
    The PWM driver just needs sufficient current capacity to provide the 1 amp current.
    Do you understand how PWM works?
  7. navidelec
    Jul 12, 2014
    29
    yes, i got it.
