I'm trying to solve a problem I am having with a small project. Basically I am looking to heat a small length of stainless steel tube approximately 3 inches long to a temperature of approximately 500 degrees F (0.194" ID x 0.25" OD). My main concern is doing it simply and, as a result, I was am trying to heat it using "impedence heating" i.e. running a current through the pipe and having the pipe act as the heating element itself. The reason this would work well is because i need the INTERIOR of the pipe to be hot to vaporize a liquid. The pipe itself is electrically isolated and I am using a variable AC transformer but as soon as I approach approximately 1 volt and the pipe becomes "warm" I blow the inline 15A fuse I incorporated. The entire circuit wiring becomes warm as well (12 gauge wiring). I understand the problem I am having is because I am basically just making a short circuit due to the extremely low resistance of the pipe. I understand they use do this on the industrial scale but can it be done on a small scale? Can I use "dummy loads" along the circuit so as to not cause a short circuit? Not sure if I'm on the right track and a little confused about how I can do this if I can... I'm hoping I can because it really would work beautiful if possible.
Any help/suggestions would be appreciated....
