impedance ratio and transformers
Discussion in 'General Electronics Chat' started by dumindu89, Sep 15, 2012.
  1. dumindu89
    Oct 28, 2010
    113
    I need to know the relationship between the impedance ratio and the number turns of primary winding and the secondary winding of a transformer.
    For an example if we take a transformer which has an impedance ratio of 1:13 what will be the number of turns of the primary winding and secondary winding?
    Then, what would be the case if it is a center tapped transformer?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
    Voltage transformation is proportional to turns ratio.
    Current transformation is inversely proportional to turns ratio.
    Impedance is proportional to the square of the turns ratio.
    On a center-tapped winding, the impedance end to end is four times the impedance between center tap and either end.
