impedance problem? in op amp circuit
Discussion in 'General Electronics Chat' started by minkey01, Oct 10, 2016.
  1. minkey01
    Jul 23, 2014
    177
    Ok, I’m back. Hehe. After studying op amps and learning LTSpice, I came up with this cv input to micro-controller circuit. It uses a rail-to-rail op amp (inverting setup) with a single 3.3V supply and a 1.65V virtual ground.
    It has a jack for cv input and two pots. One pot is the offset and the other is for attenuation of the input.
    I simulated and studied 4 scenarios and they seem to work :
    1) For manual control :
    nothing plugged into the input
    attenuation pot turned all the way up in the schematic
    offset pot=0 to 3.3V
    output=0 to 3.3V
    2) For -10V to 10V input :
    offset pot all the way up in the schematic (3.3V)
    attenuation pot turned to .165 ratio. This scales the input down to -1.65V to 1.65V
    output=0 to 3.3V
    3) For 0 to 10V input :
    turn the offset pot halfway (1.65V)
    turn the attenuation pot to .33 ratio. This scales the input down to 0 to 3.3V
    output=0 to 3.3V
    4) For 0 to 5V input :
    turn the attenuation pot to .66 ratio. This scales the input down to 0 to 3.3V
    output=0 to 3.3V
    * Here is the issue. I faked the potentiometers in LTSpice with sinusoidal volt sources, thinking that it would represent the full motion of the pots. In real life will these changing impedances at the pots mess with my op amp calculations? I'm thinking they will. Any ideas? Thanks for the help!
  2. ronv
    Nov 12, 2008
    3,393
    1,450
    You could use 2 resistors or you can download a pot from yahoo groups.
    If you can't find it there someone will have it here. If not I can do it tomorrow.
  3. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Here you go. A choice of linear/log/voltage-controlled pots:
    ronv likes this.
  4. minkey01
    Jul 23, 2014
    177
    cool. thanks!
    do you know how to sweep the pot range and have it show up in the graphical simulation when you hit the run icon?
  5. Alec_t
    Sep 17, 2013
    5,968
    1,135
    Use a Pulse voltage source to define a ramp voltage (0v-1V) for controlling the voltage-controlled pot. Plot the control voltage.
    For the normal pot you can set the wiper as a parameter and step the parameter value from 0-1.
