Hi all,
I need a low impedance electrolytic cap for a gate driver configuration, the manufacturer recommends a cap with 1 ohm or less impedance.
I've been reading some caps datasheets, however i find the data presented very confusing and it is not always show the actual impedance.
I know impedance has to do with the capacitance and frecuency, but most datasheets show it with a test frecuency of 120hz (My switching frequency is 20KHz). Can I take that reported impedance value even though the frequency they use is a lot smaller?
Other parameter is tan(delta) or Dissipation Factor, where it is represented the quotient of ESR and Xc. Some datasheets only present this data, how could i estimate the impedance only by tan(delta)?
Hope you can help me understand these parameters.
Thank you
Thank you
