Impedance of a Transformer circuit
Discussion in 'Homework Help' started by mazzi, Dec 29, 2011.
  1. mazzi
    Dec 29, 2011
    Hello all,
    Given a transformer equivalent circuit shown on the attached document of
    R1 = 2.1Ω, R2 = 5.2Ω, X1= 4.1Ω, X2= 3.25Ω, N1 = 800, N2 = 1250, R0 = 122Ω,
    X0 = 107Ω, RL = 20.5Ω, V2 = 22V.
    I need to calculate the impedance of the circuit.
    How do I calculate the impedance Z of the circuit taking account of the magnetizing branch.
  2. jegues
    Sep 13, 2010
    735
    43
    First you need to tell me whether or not the values you've given for each parameter given is referenced at the LV side or HV side.
    If they aren't they must first be reflected.
    The equivalent impedance should be as simple as a series/parallel combination of impedances provided the appropriate parameters are found.
  3. mazzi
    Dec 29, 2011
    The voltage is applied to the primary winding and the parameters are the values of the exact equivalent circuit.
    thanks
  4. jegues
    Sep 13, 2010
    735
    43
    Okay so to reduce everything down to one impedance simply preformed series/parallel impedance combinations.
    Are you still confused?
    What are you having difficulties with?
  5. MossyIRL
    Dec 29, 2011
    Your diagram is a little confusing as V1 would normally indicate Vprimary.
    But you also have Rload which is on the secondary??
    Also if this was say, the primary side, should R2 and X2 not be represented by R2' and X2'..?
