impedance matching
Discussion in 'General Electronics Chat' started by shiva bharadwaj, Nov 20, 2008.
  1. shiva bharadwaj
    Sep 29, 2008
    19
    HI GUYS,
    I have read that in a transmission line if the line impedance is not equal to the load impedance reflections take place?
    What is the exact reason for those reflections?
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    Impedance matching is important to get all the power from the source in the load.
    If there is a mismatch power can be reflected, this can lead to a malfunctioning of the source as it wants to put more power out.
    Another effect can be that the transmission line starts to radiate some of the power, wich can lead to disturbances in the surrounding.
    Here is a piece of text from agilent:
    Impedance matching is required in order to optimize the power delivered to the load from the source.
    Impedance matching is accomplished by inserting matching networks into a circuit between the source and the load.
    Source: http://contact.tm.agilent.com/Agilent/tmo/an-95-1/classes/imatch.html
    More information on transmission lines can be found here, in the links:
    http://www.educypedia.be/electronics/electroniccalculatorstrans.htm
    Greetings,
    Bertus
  3. scubasteve_911
    Dec 27, 2007
    1,202
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    This article became a classic in 1956. Nothing since has been written better on the subject.
    Eric
