Impedance Matching Transformer?
Discussion in 'General Electronics Chat' started by RJ31X, Aug 20, 2014.
  1. RJ31X
    Aug 20, 2014
    6
    I have a whole house music system, which requires, 25 ohm speakers. I have two blown outdoor speakers, which I would like to replace with Bose 151 4ohm speakers. Can I use an Impedance Matching Transformer? I have some experience, but need some advise on which one to use and how to basically connect it.
  2. Lestraveled
    May 19, 2014
    1,957
    1,218
    Interesting..... I could not find any one selling a 25 ohm speakers, nor any whole home music system that uses 25 ohm speakers. Are you sure it is a 25 ohm system?
    Do your speakers have matching transformers built on them?
  3. adamclark
    Member
    Oct 4, 2013
    472
    6
    most house systems are 8 ohm configurations,, I am an automotive electric tech. and I have used transformers to change impedance in extreme situations.. although you do raise your impendance you sacrifice ALOT of power doing so.. are you able to series 2 8 ohm speakers per side to end up with 16 ohms,,series a third one in there and you get 24 ohms
  4. RJ31X
    Aug 20, 2014
    6
    yes 25 ohm no matching transformer. the system is M&S Music & Sound they were bought out by Linear corp
  5. ronv
    Nov 12, 2008
    3,404
    1,491
  6. crutschow
    Mar 14, 2008
    13,509
    3,385
    Yes, it sounds like a 25 volt system, which uses a transformer at each speaker, not a 25 ohm system.
  7. RJ31X
    Aug 20, 2014
    6
    no! I know ohm's law. I learned it 40 years ago, and I can read.
  8. RJ31X
    Aug 20, 2014
    6
  9. RJ31X
    Aug 20, 2014
    6
    Thanks for the reply. all reply's so far are telling me I do not know what I am writing. I have been doing electrical work for forty years. I hold a state contractors license, and I went to school for electronics, and I can build computers. I am not a genius, but I am also not stupid.
  10. ronv
    Nov 12, 2008
    3,404
    1,491
    We are not questioning what you are writing. But maybe what you are reading.:D 25 volt systems are often used for long runs from the amplifier and require a special amp. Kind of sounds like you.
    Can you show a picture of the bad speaker that makes you think it is 25 ohm?
    Try looking at Nu Tone speakers.
  11. Externet
    Nov 29, 2005
    780
    58
    Yes, you can use an impedance matching transformer 25:4, with the 4 ohm winding connected to the speaker.
    RJ31X likes this.
  12. RJ31X
    Aug 20, 2014
    6
    Nutone outdoor speakers are 45 ohm. I could connect two in parallel, but they are only weather resistant, not proof, which I need. Thanks anyway
  13. alfacliff
    Dec 13, 2013
    2,449
    428
    the system is an intercom system, those use special made high impedance speakers so they work as microphones. I dont know of a source for 24 to 4 ohm impedance transformers.
    if you use a 25 volt audio transformer connected to the d25 watt tap, it will match 4 ohms to 25 ohms.
    RJ31X likes this.
  14. djsfantasi
    Apr 11, 2010
    2,911
    881
    Google is your friend. "25 ohm speaker" turns up many hits; including this one from NuTone.
    RJ31X likes this.
