I have a question on impedance matching.
If I use a transformer as the source then the secondary coil's XL and it's resistance is the source impedance-correct?
If the load is a parallel RC circuit what would be the best way to obtain an impedance match between the source and the load?
Could I insert an inductor between the source and load to match the impedance?
