Impedance matching question
Discussion in 'Homework Help' started by boks, Nov 17, 2008.
  1. boks
    Thread Starter Active Member
    Oct 10, 2008
    218
    Do we get max. power transfer by setting Z_S = Z_L both in AC and DC circuits?
  2. KL7AJ
    Nov 4, 2008
    2,047
    295
    For an AC circuit, you get maximum transfer when the load impedance is the COMPLEX CONJUGATE of the source impedance.
  3. boks
    Oct 10, 2008
    218
    And for a DC circuit simply when Z_L = Z_C because there's no phase shift?
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    that is correct. For a DC circuit, it's pretty easy to prove that maximum power transfer occurs when the load resistance equals the source internal resistance. Rather, I should say, it's easy to demonstrate....while a rigorous mathematical proof is a bit trickier.
    If you model a battery as being a voltage source with a fixed value of resistance in series, with a load resistance equal to that value of resistance, you can do a few simple calculations. Calculate what the load's dissipated power would be with a resistance matching that of the battery internal resistance. Now change the value of that load resistance to anything else, and rerun the calculation. You will not find any value that results in MORE power dissipation in the load.
    eric
