impedance matching and mic electret
Discussion in 'The Projects Forum' started by lara3m, Jan 15, 2015.
  1. lara3m
    Jan 15, 2015
    9
    I am working in a project, where i have a Microphone Electret with a impedance at the output of 2,2kohm. and a impedance matching (FET) where i am using Mosftet VQ1000J.
    My target is to see at the output of the Transistor a sinusoidal signal from the microphone.
    When i tried the circuit just the impedance matching with a signal generator at the input using
    frequency 1khz, offset 1 volt and a peak to peak voltage amplitud 2 Volts. i got the signal i am looking for BUT when i connected directly to the microphone i dont get any signal at all.
    I already tried the microphone alone and it works well.
    I dont have to much knowledge about transistors and with audio circuits.
    I know there are many things i am missing to make the connection between the microphone and the impedance matching work but i dont know which one should i look.
    I dont know if the impedance from the microphone could be a reason why it doenst work.
    any idea, i will be really grateful
    thanks in advance
    Larissa
  2. ericgibbs
    Jan 29, 2010
    2,604
    396
    hi Lara.
    Can you attach your LTS asc file.?
    Download this electret model zip.
    E
  3. Alec_t
    Sep 17, 2013
    5,980
    1,138
    An electret microphone has a built-in FET for impedance-matching. I doubt you'll get as much as 100mV out (at least, not with voice input).
  4. lara3m
    Jan 15, 2015
    9
    Hi Thank you for sharing.
    I was originally using a Jfet in the Simulation at it looks very well the signal but then now i am using a mosfet and the signal at the outpul is different. (cutted)
  5. lara3m
    Jan 15, 2015
    9
    this is the datasheet of the microphone i am using
  6. ericgibbs
    Jan 29, 2010
    2,604
    396
    hi,
    As we have said the electret mike module has already got an internal FET.?
    Are you trying to model the electret or a following amplifier
  7. MikeML
    Oct 2, 2009
    5,451
    1,066
  8. lara3m
    Jan 15, 2015
    9
    As far i saw in the datasheet from the microphone i am using, i understand that doesnt have it but i dont know if when it mean "FET Impedance converter" it refer to a internal transistor.
    sorry is the first i am dealing with this kind of components. :/
    I am trying to connect this schematic to a transistor (impedance matching)
  9. ericgibbs
    Jan 29, 2010
    2,604
    396
    hi lara,
    If you could post the datasheet for the device that would help.
    If the image you have posted is from the d/s, then it does have an inbuilt FET converter.
    E
  10. lara3m
    Jan 15, 2015
    9
    Hi i already posted,
    Here goes again. :)
  11. ericgibbs
    Jan 29, 2010
    2,604
    396
    Woops sorry I missed that. [ had a senior moment] ;)
    It does already have an FET impedance converter.
    E
    EDIT:
    image shows Zout= 2k2
  12. lara3m
    Jan 15, 2015
    9
    Dont worry. :)
    so the Zout is because the fet impedance convertor.
    The output of the circuit of the mic i need to connected to the input of a impedance matching in german "impedanzwandler".
    The Vo+ from the mic goes to the drain and the Vo- from the mic goes to the gate.
    when i connected i am not able to see any signal in the output of the fet Vds.
    i dont know which criteria should i take to match both circuits
  13. ericgibbs
    Jan 29, 2010
    2,604
    396
    This is the LTS sim I get when I use a 2N2002 in your asc file,which is similar to VQ1000.
    The overall gain is low due to the relative values of the Source and Drain resistor values, you could try a capacitor bypass on the Source resistor.
  14. MikeML
    Oct 2, 2009
    5,451
    1,066
    You do not need to worry about "impedance matching". By the time you add the 2.2k bias resistor, and the 2V bias source externally, the output impedance of the electret is fairly low, so it will drive the input impedance of almost any following voltage amplifier. You will have to capacitively-couple the signal to the following amplifier, however.
  15. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,708
    1,301
    In the original schematic, there is no ground connection to the microphone element. Also, J1 drain should be connected directly to the +5 supply.
    ak
  16. #12
    Nov 30, 2010
    16,705
    7,358
    So don't use a mosfet. A mosfet is not in its proper operating range with only 5 volts (total) to work with. But that does not seem as important as the fact that you do not need to "impedance match" a microphone that already has an amplifier in it.
  17. lara3m
    Jan 15, 2015
    9
    I am learning about this topic.
    I am doing a projekt of a professor and he give the draw of a schematic ask me to use the microphone plus the "impedance matching" to measure frequencies between 20hz to 1 khz.
    that is all.. :/ i really dont understand why he ask me to use the impedance matching even when is a already amplified, i guess is because the signal is really small to analyze.
  18. MikeML
    Oct 2, 2009
    5,451
    1,066
    Two completely different things: Impedance matching and frequency response.
    The intrinsic frequency response of some microphones (like variable-reluctance dynamic) is effected by what load resistance is connected to them (effects damping). That does not apply to amplified electret mics
  19. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Is your professor aware that an electret mic has the impedance-matching FET built-in ?
  20. ronv
    Nov 12, 2008
    3,404
    1,494
    Maybe he wants you to design the pre-amplifier for the microphone?
