Impedance calculations. Multisim VS Hand-calculated
Discussion in 'Homework Help' started by JamesCA, Jul 13, 2015.
  1. JamesCA
    Sep 4, 2013
    Hello all,
    i'm doing some impedance calculations, and what was going to be prove of concept has failed :) . The diagrams are pretty self-explanatory:
    The circuit, simulated in multisim. What i'm interested in is the output RMS voltage at probe 1 (with no load).
    My calculations:
    Xc = 1/(2*pi*f*c) = 1/(2*pi*100hz*1e-6) = 1591.5ohm
    R = 1k ohm
    for completeness:
    Z1 is just the real part of Z1 which is R = 1k
    Z2 is just the imaginary part of Z2 which is Xc= 1591.5 ohm
    which gives me, using voltage divider formula ==> vout = 20*(Z2/(Z1+Z2)) = 20*(1591.5/(2591.5)) = 12.28v RMS
    Multisim gives however 16,9 volts. I must be doing some fundimental error here. This is not homework, but seemed the best section to fit this in.
    I appreciate all comments in advance! Thanks
  2. Lool
    Member
    May 8, 2013
    117
    12
    I got the same answer you did.
  3. Jony130
    Feb 17, 2009
    3,990
    1,115
    Your calculation are wrong. The correct one looks like this
    Vout=Vin*\frac{Xc}{\sqrt{R^2+Xc^2}}=20*\frac{1.59}{\sqrt{1^2+1.59^2}}=16.9V
  4. Lool
    Member
    May 8, 2013
    117
    12
    Yep, we both forgot the j=sqrt(-1) for the capacitive reactance. Xc=-j/(2piC) which will give a phase shift and magnitude 16.9V
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    The sqrt(-1) is not part of the reactance.
    Z = R + j X
    where R is the resistance and X is the reactance.
    In this case, X = -1/(2piC)
  6. Lool
    Member
    May 8, 2013
    117
    12
    Yes, sorry for my miswording. I'm rusty on this topic.
