Hello Everyone!,
I'm trying to come up with a method to detect motion between two frames of an image. Basically, I want to take a picture, move the scene, take another picture (with at least 75% of the original scene contained), then return a vector representing the angle of movement and the relative magnitude.
I am using a 1.3M-pixel USB webcam and matlab. I am able to get the entire image into Matlab space without a problem, it's the processing that I need to figure out.
Does anyone have any idea how this is done, or how it could be done? I found a quick blurb on the internet on how I believe someone was describing how to do this, yet I am not able to decode what he is saying.
All the best!,
Stephen
Does this sound right? Can someone shed some light? I have the image processing and signal processing toolbox at my disposal.1) Use a colour camera
2) Convert to Normalized RGB to remove the effect of
illumination variation.
3) Over a protracted period, with no moving target in the
scene, calculate the mean background intensity of each
individual pixel, together with its associated standard
deviation.
4) Select a confidence level (e.g. 3xsigma) whereby the
difference between the mean image and the current image is
deemed to be statistically similar - note that regions that
are naturally liable to change (e.g. trees moving) will
have a very high sigma, and will consequently be very
tolerant of any changes in the scene.
5) Generate a binary image of all regions that contain
pixels that are outside your confidence range (e.g.
Pixel_Difference > 3*PixelSigma;
6) Track your moving image using something like blob
centroid.
All the best!,
Stephen
