I'm having a problem solving for voltage between two points
Discussion in 'Homework Help' started by barrett50, Feb 16, 2016.
  1. barrett50
    Feb 1, 2016
    14
    I'm having some problems finding the value for Vx. So far I have found the mesh current equations for all of the loops, and all that's left is Vx. Can someone help me find a starting point for this?
  2. shteii01
    Feb 19, 2010
    3,516
    515
    The fact that you can not find Vx tells me that you don't have mesh currents.
    Nice try though.
  3. WBahn
    Mar 31, 2012
    18,089
    4,917
    So... are we supposed to use our crystal balls to see these mesh current equations that you claim to have found for all the loops?
  4. barrett50
    Feb 1, 2016
    14
    I didn't say I have the currents, I said I have the equations. The problem comes in at the end of my third KCL that is
    8(Iy-I3) + 6(Iy-I2)+3Vx
    My problem is that I don't know what I'm supposed to substitute in for Vx.
  5. shteii01
    Feb 19, 2010
    3,516
    515
    What is that equal to?
  6. barrett50
    Feb 1, 2016
    14
    So I labeled the first box I1, upper mid box is I2, lower mid is I3, and right box is I4. There is a supermesh at I2 and I3. I go clockwise
    I1 = -4 (A)
    KCL at SuperMesh
    3(I3-I1)-2+5(I2)+6(I2-I4)+8(I3-I4)
    KCL at I4 is
    KVL for the dependent current source is
    Iy=(I2-I3)/7
  7. shteii01
    Feb 19, 2010
    3,516
    515
    Anyway. Vx=2+3(whatever currents pass through the 3 Ohm resistor)
  8. WBahn
    Mar 31, 2012
    18,089
    4,917
    These are not equations, they are expressions. Equations involve this thing called an equals sign.
    Also, you need to specify which direction your mesh currents are circulating. Otherwise there is no way to know if your value for I1 is correct or not.
