I'm circuit challenged....
Discussion in 'The Projects Forum' started by bigwelsh21, Mar 3, 2009.
  1. bigwelsh21
    Mar 3, 2009
    6
    Im looking to design a multi-recordable sound play back device? kinda detailed is it possible to hire somebody or would someone with 0 circuit and electronic skills be able to figure it out??
  2. mik3
    Feb 4, 2008
    4,846
    63
    What do you mean by multi-recordable?
    How many KB of memory?
  3. bigwelsh21
    Mar 3, 2009
    6
    like a remote type thing that played back 3 seperate sounds
  4. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    What duration of sound and what degree of fidelity?
  5. Oxbo Rene
    Feb 20, 2009
    200
    Will it require an audio modulated regeneration resonating frequency transducer, or a Piezo Element ??
  6. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Or just a speaker and microphone? Or just input & output connections for whatever is used?
  7. bigwelsh21
    Mar 3, 2009
    6
    umm..youll have to bare with me fellas im not good with this.. i want like
    memory1:when you press the m1 button a fairly loud noise would follow immedietly
    memory2:when you press the m2 button lets say the word "run!" would play
    thank you guys for the posts any help is greatly appreciated, im very devoted to making this project work just wasnt sure if someone at my level with no skills would be able to make it happen. is it possible to hire some one or is this a simple project?
  8. packrat
    Member
    Feb 25, 2009
    12
    If you don't need to record any new sounds other than those two that you listed, and sound quality is not a major issue, then you could probably pull that off very simply with an Arduino board and some PWM code if you have some experience with C programming.
    I worked on a project rather similar to that, but the sound quality and volume weren't too spectacular. With some amplifying speakers however, I got the job done.
    There was also a bit of a delay (about 1 second) between the trigger and the playback. Would this be a problem?
  9. KMoffett
    Dec 19, 2007
    2,584
    234
  10. bigwelsh21
    Mar 3, 2009
    6
    the response has to be instant....you guys are genius's that links great helps alot i appreciete everything..
    welshbjj20@yahoo.com if anyone can possible give me a price quote on this project..
  11. KMoffett
    Dec 19, 2007
    2,584
    234
    bigwelsh21,
    Go back and edit out your email address from your last post. Bots scan forums and pick out email address for spam. People can use the forum's Private Mail to contact you.
    Ken
  12. bigwelsh21
    Mar 3, 2009
    6
  13. Ron H
    Apr 14, 2005
    7,050
    657
    WTH is an
    :confused:
