I'm Back
Discussion in 'Off-Topic' started by Sparky49, Sep 7, 2012.
  1. Sparky49
    Jul 16, 2011
    835
    417
    I'm back chaps.
    I got the test papers back and they're are quite crap. I don't understand why I made the errors I did. Even then, some of the marking seems quite strict and very confusing.
    I got 4 out of 6 marks for describing how to use an oscilloscope - now, seeing as I use one nearly every day, I would have thought I would have got a better mark - looking at my answer now, I still can't think of anything I haven't mentioned short of "turn it on".
    Also, there's absolute nonsense with calculations on parts of it - for example, I didn't get any marks for a couple of questions because I didn't draw lines to show the points where I got the gradient - nevermind that I actually used maths and got the correct gradient.:mad:
    Anyhow, back into the swing of things, so I plan to do some more tinkering. I want to get back with uC's, so I'll dig out the boards and books.
    Keep an eye out.
    Sparky
  2. steveb
    Jul 3, 2008
    2,433
    469
    Welcome back!
    They say, "you can't keep a good man down".
    Sparky49 likes this.
  3. Sparky49
    Jul 16, 2011
    835
    417
    Thank you Steve, I will also aim to help beginners out a little more.
    Some people liked my explanations of things like 555 timers, perhaps I could offer some other explanations now my knowledge has increased slightly.
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    We 've talked about this before, but exams can be completely out of place. What's the merit of a question that asks you to describe the use of an oscilloscope? Get the lad in a lab and let him show you! Bureaucracy sometimes puts you miles behind.
    Sadly, you must work within the system if you want its merits.
  5. Sparky49
    Jul 16, 2011
    835
    417
    Another point seemed to suggest I was copying!
  6. loosewire
    Apr 25, 2008
    1,584
    435
    Sounds like you started from the top down on the scope,there are such things as
    average and peak voltage,just for one. Using the source voltage you need to know
    how to calulate these voltage too. Good luck on your new beginnings,read the
    instruction manual,so you know what the scope does in detail.
  7. Sparky49
    Jul 16, 2011
    835
    417
    In class we were only really taught the very basics, time base, voltage etc.
    I explained this and even talked about afew other points like triggers just to make sure.
    I will wait for the mark scheme. D:
  8. loosewire
    Apr 25, 2008
    1,584
    435
    What do you mean D that failing ,you didn't say you read the manual..
