Illuminated Switch help please
Discussion in 'The Projects Forum' started by Addbuyer, May 26, 2009.
  1. Addbuyer
    May 26, 2009
    Hi Guys & Girls!
    I need to put a 12v illuminated switch into a simple circuit but the switch has 4 terminals which is confusing me!:confused:
    I have a 4.2 amp 12v supply (+ & -) and want to run 3 computer fans which will draw less than 1 amp
    I purchased one of these switches to do the job http://www.maplin.co.uk/Module.aspx?ModuleNo=34859
    Two of the terminals are marked only i.e. one marked Plus the other negitive, but the other two terminals aren't marked and so i can't figure out how to wire it up
    If it had been a three terminal switch then i believe one would be power in, one would be power out and the third would be ground
    Can any of you help please. Thanks Andy
  2. gerty
    Aug 30, 2007
    1,154
    304
    First make sure the light int he switch is rated fro 12v and not 120.
    From your description it sounds like it is, the +and - being used for a led. The other two terminals are your switch. You would tie the - to the negative or ground, the + would go to the wire that is being switched and the two other terminals would be your + in and your switched out.
  3. Addbuyer
    May 26, 2009
    Hi Gerty,
    That makes sense now! I will give it a go.
    Thanks for the fast reply
    Andy
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The FAQ indicated that a 430 ohm resistor is needed for 12 volt operation so the LED does not burn out.
  5. gerty
    Aug 30, 2007
    1,154
    304
    Good catch beenthere, I forgot all about the resistor!!
