Some ignition coils with built-in transistors require a ground signal to fire. Could someone further explain? Does that mean a ground signal must be fed into the transistor's base so that it turns on and allows current through the primary winding? What really is the difference between a negativetly triggered coil and a positive triggered coil ?
Thanks!
Thanks!
