igbt
Discussion in 'The Projects Forum' started by arunpradh, Sep 3, 2014.
  1. arunpradh
    Dec 11, 2013
    43
    where can i get deeper data about igbt. usually it's switching at higher frequencies
  2. crutschow
    Mar 14, 2008
    13,475
    3,361
    A good place to start is the data sheet for the IGBT you want to use. IGBTs are fairly slow switching as compared to MOSFETs and BJTs.
    arunpradh likes this.
  3. ScottWang
    Aug 23, 2012
    4,925
    777
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    An IGBT is effectively a MOSFET switching a BJT. It's not ideal at high frequencies (like MOSFETs are), but is often used in high-power applications as there is usually less of a voltage drop across the collector and emitter. A MOSFET is an ohmic device, meaning the power that is wasted due to the voltage drop increases exponentially with current (P = I²*R). A BJT, on the other hand, has a fixed voltage drop based on the semiconductor properties (0.7v, for example), so the wasted power is linear (P = V*I) and in high power applications, this is the most efficient.
    Equivalent circuit:
    Please note that this is only a representation, and does not accurately show what the inside of an IGBT really looks like.
    arunpradh, to3metalcan and #12 like this.
  5. crutschow
    Mar 14, 2008
    13,475
    3,361
    An IGBT actually has over a two diode drop which is typically about 2V (as noted here).
  6. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I was just using 0.7V as an example because everyone knows that's the diode drop of a regular silicon diode. You're right though, there's more to it than that. Thanks for bringing that up!
  7. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Here is something from IR
    Max.
  8. ScottWang
    Aug 23, 2012
    4,925
    777
    If I want to using mosfet and bjt to simulate the IGBT in the real world, do you have any suggestions numbers for them?
  9. crutschow
    Mar 14, 2008
    13,475
    3,361
    Use the equivalent circuit that Max showed (with a resistor in series with the BJT base to give a base current 1/10th of the maximum collector current) and add a silicon junction diode in series with the emitter output terminal.
  10. ScottWang
    Aug 23, 2012
    4,925
    777
    Thanks.
    But I was asked for the parts numbers of mosfet and bjt.
  11. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    That depends entirely on your circuit.
  12. ScottWang
    Aug 23, 2012
    4,925
    777
    How about for a AC110V 500W application?
    The Vce =60V for bjt, Vds=200V for mosfet, those voltages of parts are what I have and usually use.
  13. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Well first of all you really should not use BJTs or MOSFETs to switch AC. For that you really ought to use a TRIAC.
    You must make sure that the transistor that is carrying the full current can handle it. In an IGBT the main current-carrying transistor is the BJT, so your BJT must be able to handle the full voltage and current that you're trying to switch.
  14. ScottWang
    Aug 23, 2012
    4,925
    777
    Normally I will use TRIAC, but I'm trying to use a diode has big current and in series with the output of bjt.
    If I want to make a dimmer using triac for AC110V/500W , do you have any TRIAC number in hand?
    I was thought maybe use parallel method to increase the power, the dimmer I had can be adjust the fan, 100W lamp, 60W solder iron.
    I knew that, as I mentioned that the bjt I had only 60V as 2N3055, if I'm trying to use in 200Vdc/2A, 400Vdc/2A, do you have any bjt number to try?
    Why I want to try this, because the IGBT is too expensive, so I want to use the mosfet and bjt to simulate.
