IGBT vs MOSFET
R!f@@
Joined Apr 2, 2009
9,918
See the file attached.
A seller said the MOSFET will work instead of the IGBT.
App is a tread mill motor controller.
I on the other hand does not think so. Correct me please.
strantor
Joined Oct 3, 2010
6,798
I don't know the answer. I don't see any reason why it wouldn't work. When I calculate watt loss both, assuming 20A tradmill motor, they are almost identical. I am curious why you think it won't work.
t06afre
Joined May 11, 2009
5,934
I would say it is worth a try. They both have about the same switching times. And VGE versus VDS fully on looks also to be compatible
ramancini8
Joined Jul 18, 2012
473
IGBT:
I=10A, P=21W
soft recovery diode
non-punch through
short circuit capability (10Us)
FET:
I=10A, P=78W
The IGBT seems to be a better choice, and that is why it is often preferred for motor applications.
ScottWang
Joined Aug 23, 2012
7,400
MOSFET STP10NK80ZFP - V(BR)DSS=800V,RDS(on)=VGS=10V,Id=4.5A,0.78Ω.
IGBT IRGIB10B60KD1 - VCES = 600V,IC = 10A,VCE(on)=1.7V.
IGBT Calculation:
R = 1.7V / 10A = 0.17Ω
IGBT VCE(on) = 1.7V, when IC = 10A, W = 1.7V * 10A = 17W
MOSFET Calculation:
Vds = 4.5A * 0.78Ω = 3.51V, W = 3.51V * 4.5A = 15.795W
IGBT to MOSFET Current rate = 10A/4.5A=2.222
Vds = 3.51V * 2.222 = 7.8V
W = 15.795W * 2.222 = 35.096W.
The power dissipation rate of MOSFET to IGBT :
PD_rate = 35.096W / 17W = 2.064
If my calculation is right then the power dissipation of MOSFET is more than IGBT.
strantor
Joined Oct 3, 2010
6,798
IGBT:
I=10A, P=21W
FET:
I=10A, P=78W
IGBT Calculation:
MOSFET Calculation:
You guys are right on. My calculation was out to lunch since I misread the datasheet and did math for 20A @ 0.09ΩRDSon
t06afre
Joined May 11, 2009
5,934
So..this is new.
Will it be safe to switch the IGBT for the MOSFET then ?
Nah...not sure any more. I forgot to take the power dissipation into the consideration. It will most probably overheat. Due to insufficient heat sink. As the heat sinks are dimensioned for the IGBT. You should try to find a FET, which is as fast as the IGBT and RDS(on) around 0.17 ohm. Then one suggested will probably work for while then break down
ScottWang
Joined Aug 23, 2012
7,400
To see what I posted on #6, and another parameter that you should care about that is frequency.
Comparing every parameters and considering what's your application, and then make the last decision.
R!f@@
Joined Apr 2, 2009
9,918
Well! guess what?
It ran for a half an hour without a load (Empty belt). But as soon as some one got on the belt it suddenly increased speed and KAPOW!
