IGBT transistors
Discussion in 'The Projects Forum' started by Kh_genius, Apr 3, 2006.
  1. Kh_genius
    Feb 27, 2006
    please, can you tell about the number of IGBT transistors with low cost.
    I need them to use them in a 4-Quadrant Chopper to use it in a DC motror speed control.
    the Nominal voltage source is 40 volt Max for the motor.
    Thank you,
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Hobby or commercial?
    I've had excellent luck with eBay for hobby components.
    What is your expected peak current?
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Would you please specify what you consider low cost. Are you going to buy a few or will there be a volume order. If you have a relationship with a distributor ask for samples. Free is as good as it gets.
  4. Kh_genius
    Feb 27, 2006
    My expected peak current is 10Amp
    The cost has a range (5 - 10) $
    If you have any model number of the IGBT's, please reply
  5. Papabravo
    Feb 24, 2006
    10,340
    1,850
    How hard did you try to find these parts? A two click query to DigiKey produced
    10A Part
    Fairchild ISL9V2040 cut-tape $ 1.78, bulk $1.90
    15A Part (you do want some margin right?)
    OnSemi MPG15N40 bulk, $2.70
    OnSemi NGD15N41 cut-tape, $1.84
    Where do I send my bill for purchasing services? I'd say less than half your minimum price was a good days work, eh? (Just kidding about the bill part, but my wife makes big bucks as a purchasing manager; she does this stuff day in and day out)
