HI,
I need to design an inverter in a half bridge configuration that needs to drive a 2KW motor. For this purpose i am on the lookout for an IGBT that satisfies the power requirements. In this context i should add i am not very comfortable with the concept of IGBTs. I was considering the IRGP50B60PD chip and i would like clarification on some terms i found. The data sheet says Id for this chip is 50A, this means that the amount of current that can pass through the collector-emitter is 50A(in case if this is not right please let me know).
My problem starts with the Vces which it says is 600V. What does this quantity signify? does it mean it can push 50A of current @ 600v ? If that is so and if i am operating at 25C would this IGBT be good enough to power my motor, since P=VI = 50*600 = 30000w o/p ?
Here is the link for the datasheet
http://www.irf.com/product-info/datasheets/data/irgp50b60pd.pdf
Also what does the Vces(br) signify?
TIA,
Bob
TIA,
Bob
