I have never heard about them but i guess from the name that they are very fast parallel diodes with the ones anode connected with the others cathode and the others anode connected with the others cathode.What is the meaning for anti-parallel hyperfast diodes for an IGBT?Does it means they cannot be parallel up ?
Yes, that exactly what it means. It's s bit of a misleading name, as it is not the parallel arrangement that is "anti" but the polarities - and even then "anti" should be inferred as "reversed".I have never heard about them but i guess from the name that they are very fast parallel diodes with the ones anode connected with the others cathode and the others anode connected with the others cathode.
mik3's explanation of anti-parallel is correct, namely that devices (lets keep it abstract for the moment) are connected in parallel but with the polarities reversed. The notion of "anti-parallel hyperfast diodes" takes some reading into, and without seeing it stated in context I cannot offer more of an explanation from an application point of view.I always thought the term used by the OP meant the single diode that is placed "anti-parallel" between the source and drain of IGBT's and Mosfets to protect from inductive kick. The diode's cathode is attached to the high-side potential. Thus, it conducts opposite to the IGBT/Mosfet device.
It is not a pair of diodes connected as described. That connection described by Mik3 conducts in both directions and would not be a good idea across the drain and source of a IGBT/mosfet. John
See the attachment (you don't get any fancy layouts with me John, drawn by hand on a tablet!!).Hi Dave, I am not sure of the circuit you propose, particularly the phrase, "switch operational through each device."(emphasis added) Can you post a schematic?
To clarify my comment, I have added a schematic. Unfortunately, I couldn't find an IGBT device in Eagle, so I used a Mosfet. Just assume for now it is an IGBT. Circuit A is what I am referring to. The diode is often referred to as the anti-parallel diode in the way that the OP referred to it. Circuit B is simply two anti-parallel diodes (Mik3's description). Circuit D is a Triac and C is a Diac.
The circuit you describe sounds to me a lot like a triac with control of the gate...much like an scr with gate turn-off control. Obviously, I am confused, so a picture would help.
In any event, I think the OP was referring to the configuration in Circuit A.
John
So it is as John described. Interesting little device.here's a datasheet
