IGBT High side driver
Discussion in 'The Projects Forum' started by sriniketh, Aug 24, 2015.
  1. sriniketh
    Jul 7, 2015
    29
    I am making a circuit with IGBT for charging a capacitor. The Driver
    which i use is a high side driver as suggested by Infineon.I have
    received working spice model of the driver from Infineon for my
    application. however the simulation in LT spice is not giving required
    output and also it is very slow.I have also tried the same concept with power MOSFETs. i am attaching the simulation file.
    Kindly guide me in finding the error.
    Regards
    Sriniketh
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    Your circuit includes other parts that are not in a standard LTSPICE library. In order for me to run it, you will have to create an isolated subdirectory to build your circuit in. That subdirectory must include all the files for the non-standard components: all .asc, .asy, .lib or .sub
    You will need to post a .zip file which contains everything required to run the simulation.
    sriniketh likes this.
  3. sriniketh
    Jul 7, 2015
    29
