IGBT Help
Discussion in 'General Electronics Chat' started by deepak3s, Mar 13, 2009.
  1. deepak3s
    Mar 13, 2009
    Having tough time finding this IGBT Module. Any help in finding a manufacturer will be great.
    Attached a scan of the device.
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    That looks more like an SCR module. Do you need the exact thing or just a workable replacement?
    John
  3. deepak3s
    Mar 13, 2009
    Thanks John... I would be happy getting any thing.... exact would be more appealing though... but in any case a working replacement will also do just fine...
    Deepak
  4. deepak3s
    Mar 13, 2009
    The ratings by the look are 40A 1200V
  5. jpanhalt
    Jan 18, 2008
    5,699
    909
    That is a fairly common rating, and it should be easy to find something that will work.
    Industrial modules can be pretty expensive. I have used ebay (search: (scr, thyristor)) and find they generally can be had for about $10 each. If you get too many hits with that, try business and industry only or add (Westcode, Powerex, Semikron). Semikron is very common and has numerous offerings with the scr and diode combined. You need to pay attention to the schematic. There are 3 diodes, not just two. Also, it has two scr's. I have seen similar modules, but you might also consider using two, scr+ diode modules.
    How is the module you have being used?
    John
