I guess the (rather ambiguous) question is what maximum heat sink thermal resistance is allowed for the stated conditions.
One bit of information missing from the attachment is the maximum permissible junction temperature - Tjmax
Suppose Tjmax=150° C
At Ic= 50 amps the piecewise model tells you
Vce=0.1+0.05*Ic= 0.1+0.05*50=2.6V
The collector dissipation at 50 A will then be Vce*Ic=2.6*50=130W.
With Tjmax=150° C and Tamb=45° C the permissible temperature differential from junction-to-ambient is Tja=150-45 or 105° C.
With 130W collector dissipation the maximum thermal resistance from junction-to-ambient is therefore Rth(j-a)=105°/130W=0.808 °C/W
The junction-to-(heat)sink thermal resistance Rth(j-h) is the summation of the thermal resistances from junction-to-case and case-to-(heat)sink
Rth(j-h) = 0.2 °C/W + 0.3°C/W = 0.5 °C/W.
So the maximum allowable heat sink thermal resistance is the total allowable junction-to-ambient thermal resistance less the IGBT's junction-to-(heat)sink thermal resistance
