I recently purchased a couple of Mitsubishi MG400Q1US41(EP) IGBT Modules 400Amp 1200Volt
I want to control them with a cheap lm317 dc power supply using 17v 1.5 amps. or Should I UP THE AMPS TO 3amp power supply?
Can I just connect the igbts to a full wave rectfier after the 3800uf 450v caps?
Then manually control them using the lm317 power in a separate power supply ?
at this point, im just testing them out to see what happens.
I will be feeding the 35amp 800v full wave rectifier with a 10amp variac and using a dummy load.
what would be a good dummy load? or resister wattage and ohm ?
maybe I can use the igbts somehow in a welder or high power supply.
I can always use a few extra amps for something
Thanks for the advise
